Re: Difference between AQ271 and AQ311
311 is rated for 4600 to 5200 WOT rpm. 271 is 4200 to 4600. So yes, the HP is coming mostly from the higher rpm.
Some things I found different by looking at the service manual specs.
311 has 4 bolt main bearings, 271 is 2 bolt.
Cam has higher lift on 311
Timing 2? different, carbs the same.
Everything else seems to be the same.
