Difference between Celebrity "CX" or "STATUS"?
paulspaddle
1993 Celebrity 180 "CX".
Looking at NADA and the stats here on iboats does anyone know the difference between the "CX" or "STATUS" models?
Both have identical length and beam and weight...must be a trim level?
paulspaddle
Re: Difference between Celebrity "CX" or "STATUS"?
Do I get a prize for stumping the crowd? :D
5150abf
It proabbly is just a trim level or they may have just changed the name of the boat without changing anyhting on the boat, that is fairly common.
It is the same hull so it has to be just a trim level.
paulspaddle
Thanks, and I agree.
Just curious if someone actually knew specifically as these two names go on for years. You can find different motors, different seating layouts, different dash 'looks', under each of these names so I can't figure out what makes up the difference in the trim level.
In the grand scheme of things it doesn't really matter, I'm just obsessing because I can't figure it out. :confused::D
