I took my new boat for the first time, a 16" Glastron w/ '79 Merc 115, and it ran wonderfully. I had just de-carbed it and was planning on changing plugs after I put it under load for awhile per someone's suggestion. On the second trip with new plugs it wouldn't idle (kept cutting out) and performance was awful. I went from NGK plugs to Champion. These are the type of plugs with no electrode and gap is non-adjustable. I'm 100% that the wires are on the correct cylinders and connections are tight. Could I have a bad plug and what is the best way to test for spark, please be detailed with procedure as I'm new to this. Or do different plugs vary this much from brand to brand? Or do I have another problem altogether?<br />Thanks in advance...
