Newly acquired 1975 Evinrude 20hp on a 14' speedboat..<br />Runs like a top...all the time....YAY!
<br /><br />BUT....was flushing it out after being in the salt water (The manual says no internal flushing is necessary, but I do it anyway)..<br />Anyways, stuck the garbage can under it (on the boat still) and filled it with water, well over the intake port. <br />I started it and ran it for a few minutes and made sure that it was pumping water out. Shut it off, and felt the urge to start it again...not sure why, except that I'm a guy and I like the noise and smoke.<br />This time, no water spitting out.....ugh. I watched it for a few minutes, and nothing was spitting out the outlet (water outlet/exhaust overflow it says in the manual..) and next to no glub glubbing from the prop area. I was just about to shut it off when it made a belch and started spitting water and steam out the spitter, and the glub glubbing at the prop was back.<br />What's up with that..? Could it be that all the exhaust was coming out the water outlet, and was restricting the flow of water..?<br />Or should I consider tossing in a new impeller?<br />Like a fool, I forgot about this incident and went out the other day. Motor ran like a champ. Thought of the water problem halfway home. *whew*<br /><br />Is this normal operation for a thermostat? Does this motor even have a thermostat? Does it indicate a bad thermostat?<br /><br />New motor to me. Sorry if the answer is obvious and I just don't know it
<br />Or am I just looking for problems that aren't there?
