I bought a used boat which had great difficulty starting and running smoothly. I had the carb rebuilt which now has helped the engine run smoothly, but it will not a start unless I push the throttle forward just the right amount... EVEN after it has run for 30 minutes and is plenty warm. This is quite annoying as it usually takes multiple attempts to get it started. The plugs and compression in each cylinder are good. Ignition system/coil coil seem to work fine. Any ideas?
1996 5.8L 351W engine, 4bbl Holly carb, volov DP outdrive.
Thanks for any help you can offer, AJ
