shoestring
- Joined
- Apr 25, 2009
- 107
hi all. i was just given a 56 mark 25. i think it would be kind of cool to get this old girl up and running again. compression is good, but spark to only one cyl. i pulled the flywheel and seen that the coil covering is split pretty bad on both of them. so new coils are in order, along with points, plugs, and condensers. but lets dig a little more before we go spending money. tore the lower unit down to find the impeller is shot. no evidence of over heating that i can see. the bearings seem to be in great shape along with the sealing surfaces on the shafts. except with the drive shaft sealing surface below the impeller. a 0.625 speedi-sleeve would fix this right up. gears are in great shape, it dosent look like this motor has ever seen much use, the prop has about 90% of the original sunset orange paint still on it, i hardly think it has been replaced. carb is clean but should have some new parts put in it along with the fuel pump. the only damage i see it the casting on the side of the motor below the tiller handle. there is a block of aluminum that the tiller haldle rests against when you fold it down, well it is broke off allowing the handle to lower down too far. probably fell over in someones garage. a scrap of aluminum, drill, tap, 2 screws and maybe a little jb weld could fix this right up. i would like to get a new impeller housing but seems they are NLA. some fine steel wool should smooth things out enough for a new impeller to last. other than that just a little cleaning and some lube on the moving parts and i should be in business. I have my parts list here and am ready to order but would hate to spend the money to find another problem that i didn't notice. if any of you guys have any experience with these old mark motors, i'd sure like to hear from you, and learn of any inherent problems they might have. I hear they could use new crank seals from time to time. crank bearings seem nice and tight with no noticeable end/side play. area under flywheel is clean and dry, no oil here so i'm thinking that seal is ok. no idea on the lower one though. the thought of having a good reliable 20HP!!!!!! outboard makes me all warm and fuzzy inside. i'm up to about $300 bucks on my parts list and willing to do it. i think i'll do a little more tinkering and inspecting while i wait for a reply from you guys. thanks
