Dimensions on Fuel Cell
Hodgey4489
Hello,
New member here. Thank you all for your knowledge in advance. I recently purchased a 1974 22’ Starcraft SS. I’m going to be restoring it. I have not started yet, but I came across a fuel tank on Craigslist for $25. It’s aluminum and it is for below deck installation. I was curious if anybody knows roughly the necessary dimensions that would fit?
The dimensions of the tank are 46” x 23.5” x 8”
My concern is the width and height of the stringers. Thanks all and Merry Christmas.
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
Howdy and Welcome.
You will find a trove of information here, but some of it you will have to find yourself on your boat.
In the case of your question, there are a lot of variable and the depth will change depending on where you measure from. Plus is your boat built for a V shaped tank or a flat bottom tank? Anyway to cut a hole and determine what kind of tank you already have or is it topside currently?
SHSU
Hodgey4489
Howdy and Welcome.
SHSU
Hi SHSU,
Thank you for your reply. The current tank is topside. I planned on having the tank in the middle but a little more to the bow. From other images I’ve seen with my boat I’m thinking a V shape. I could cut a hole and see to make certain. I may just purchase this tank 25 USA good price if it doesn’t work it’s extra fuel storage I suppose.
