This is my first post, here is my problem I own a 1988 5.7 OMC that I recently had in the shop because I took out the "do not take out" plug on the lower unit. I took it in to a shop that works on OMC's and they got the brass nut out of the exhaust and changed the lube in the lower unit along with the impeller. I want to check the lube to make sure its where it should be but I can't get the dip stick to move. I called the shop and they told me that they are tight, and the mechanic made a tool to get them out with a socket. I'm sure he cut the shaft off a wide screw driver and fit it to a scoket, my problem is my biggest screwdriver won't fit under the swim platform and I tried to use a crescent wrench on the shaft of a screwdriver and I could see the shaft twisting. Should I just stop by the shop on the way to storage and have them loosen it up for me or is there another way. Thanks for any help. If they filled the lower wrong will the lube still show on the dipstick? This is the first OMC I've owned so I"ll have more questions I'm sure.
