Re: Directv Box Connections
You can transfer it to dvd, after recording to a set top dvr, thats what I do on a digital cable signal, but if your dvd burner is housed in a computer you will need some sort of video capture device, be it a card or some other way, there are surprisingly many. The V.C. card is the easiest way to go. Essentially you will be creating a P.V.R. (personal video recorder) on your computer and then converting it to a dvd, you will need a rather large hard disc as the space required to record the "shows" will need to be free. What I do is record them to a hard drive then burn them then "erase/delete" them from the hard disc. I haven't done this with any type of satelite signal but i assume the process is relatively the same as recording from my set top dvr box. Also the programs sometimes need to be compressed to fit on a dvd. If you search for pvr to dvd recordings you will find a wealth of info. Also, I will try to answer any questions you have. However, I don't really check in here but once every couple weeks. Best of luck.
Dale
