disassembly of shifting/ignition handle??
georgiaboy
I have a 1987 johnson 40 and i am trying ti check the wiring in the shiflting handle box. I took the 3 srews out and the allen screw that is the middle of the gear looking thing on the back but still can't brake housing apart-HELP
tashasdaddy
Re: disassembly of shifting/ignition handle??
remove the handle, which the allen screw held. does your have the black pad, on top. if so remove those 4 screw, and the pad. now gently pry apart. get your camera and take pictures as you go. everything has to be in the right place to close.
F_R
If the handle seems to be stuck, put the allen screw back in, then loosen it about a turn or so. Then give the screw head a whack with a hammer and punch. The handle will pop right off.
