Speakrdude
Ensign
- Joined
- Feb 25, 2004
- 942
So, repowering 96 Maxum 3200SCR (big boat!) Both blocks (7.4L Gen V's 4BBL) froze and broke, bought it that way. No PO info available. Drives (Bravo III's)
Removed the drives, cleaned the surfaces, painted etc.
Rebuilt (completely) both gimbal housings.
U-joints looked/felt fine. Greased all.
Everything spins good, shifts good etc.
Gimbal bearings felt good, reused, greased.
Installed two freshly built 7.4L's. (used alignment tool. good to go, both drives)
Broke in port engine yesterday, in her slip. (first time to run) 2000 rpms, min 30 minutes. Life is good. Adjusted timing, idle, shifted drive, forward/reverse, all good.
Broke in Stbrd engine today, same process, all is good. shifted forward/reverse, yada yada
AND THEN,
I decided to check port engine again. Started right up, then rrrrrrrrrrrr, sounded like a chainsaw in the fan belt.
Went to inspect, and discovered the drive shaft was not spinning and the hub had stripped itself out. (That was the rrrrrrr sound)
So, what do you think?
A. Bad hub. (that's a given)
B. frozen drive, causing the hub to strip?
Have to pull drive first, so I will figure that one out right away.
AND THEN,
