discolored piston head/ low comp
huddled
94' merc 200 hp with rebuilt power head. 60lb comp in one cylinder with silver colred piston heads??
j_martin
Re: discolored piston head/ low comp
Water intrusion steam cleans it. Probably bad head gasket.
If all the pistons are super clean, yer in deep doo-doo.
o/b tech
How was the burn on the spark plug???? What do you mean by silver coloured head?? Was the piston crown silver or the head??? How many hours on the rebuild??? Was the motor overheated etc.
verado7
silver pistons is good - no carbon build up -you should see a film of oil on it though or look wet - however 60 psi on 1 is not good
