Distributor advance curve for a heavy boat
Finnerty
My 26ft Tollycraft is running fine with the single Mark IV 454 on a 2:1 V-drive, but I’m wondering if I can improve performance by adjusting the advance curve on the distributor?
This is a 10,000 lb flybridge cruiser, 26’8” LWL, 10’ beam, runs at 7 knots at 1700 rpm most of the time, or 14 knots on plane at 3200 rpm when we are in a hurry to get across to Vancouver.
It has a Mallory points ignition that replaced the original distributor a while back. I am only now understanding the concept of properly curving the distributor.
With my initial advance set at 8 degrees BTDC at 800 rpm idle, I measure centrifugal advance up to 5 degrees higher than the max spec in the Mercruiser manual mostly at the lower 1700 rpm that I spend 90% of the time at.
So should I dig into my distributor and try replacing springs or just leave it alone as I am not hearing any pre-detonation?
Is there a general rule of thumb that slow heavy boats should use a slower curve, or the opposite?
1977 Mercruiser Mark IV BBC
800 hours on rebuild
Serial #5551947
2:1 Borg Warner V-drive
Mallory Points Ignition
Coil, ballast resistors, dwell all within spec
22 degree or 24 degree advance? Both OK
Your base timing should be set at 650 rpm
Load is load, engine doesnt know if its spinning a low pitch prop pushing a big boat or a high pitch prop pushing a small boat.
It only knows RPM and BMEP
What is the max RPM the v-drive is rated for. Because at 3200 RPM, the motor has another 2000 RPM to go
Finnerty
Scott, what does BMEP mean?
Max rpm for this MIE 330 is spec’d at 3800-4200 rpm in the service manual.
My WOT is 3850 rpm turning a 19x17 3-blade prop on the 2:1 V-drive.
The manual gives a min and max advance curve that gives the range for this engine.
Total spark advance minus initial timing is spec’d at 5 - 9 degrees at 1700 rpm (the engine speed I usually run at). My advance is 14 degrees (so plus 8 initial is 22 total).
At 3200 rpm, spec is 18 - 22 degrees, I’m at 23 degrees (31 total).
At 3800 rpm and up spec is 22 - 26 degrees. (I didn’t test mine at WOT.)
Thanks for the help!
