allyolds68
- Joined
- Jun 17, 2012
- 30
I've got a 97 Sea Ray 210 with a 5.7 Mercruiser with about 300 hours. it's a non-vortec, carbureted motor. Engine Serial # 0K026581. I purchased this boat about a month ago and spent a lot of time going over it before purchasing it because the previous owner told me it fell flat over 3000 rpm's. I was confident that whatever the problem was I could fix it. It has good compression (150 psi on all cylinders). I changed wires. distributor cap & plugs. When I pulled the old coil wire there was substantial corrosion in the coil plug (the coil mounts vertically and moisture can get trapped in it). I thought that may have been the reason it wasn't running well over 3000 rpms and indeed, the first few times we went out it seemed to run very well. One thing it seemed to be doing was sucking a tremendous amount of fuel. A couple times while tubing the engine dieseled after turning it off to let a rider in or out of the boat. I caulked it up to turning if off too fast and not allowing it to cool. Last weekend it started to really run like crap and had no power over 3000 rpms. I pulled a couple plugs and they were BLACK. My first thought was because I knew the previous owner had run ethanol pump gas in it, the carb probably needed to be rebuilt. I did a rebuild on it and other than having the float set too low I really didn't find anything wrong with it. After reinstalling the carb today I checked the timing (purple wire with white stripe grounded). The timing appeared to be set at ZERO (TDC). The timing for this motor, according to the air cleaner, is 10 degrees. I loosened the hold down bolt and tried to rotate the distributer to advance it but there's a bracket on the back side of the distributor that hits the bracket for the engine wiring harness and doesn't allow the distributor to rotate to any more than about 1 degree. All these brackets look factory. I can't believe this boat has been running since 97 like this. I don't think the balancer has spun because the motor only has 300 hours on it. I disconnected the wiring harness bracket, advanced the timing to 10 degrees, and it seems to run great now. I'm uncomfortable that I'm lining up with the correct mark on the timing cover. I've circled what I think is the timing cover mark below. The second picture below that is hard to make out but it's the conflict between the brackets
