PitchFork
- Joined
- May 28, 2009
- 313
I have a 1994 GM 305 motor that starting leaking drops of oil during the summer. I would see rainbows in the water on the pavement when I pulled the plug out after a days boating. This week I changed the oil becuase 100 hours is up and starting to look for the leak and found a small puddle to the left of the distributor. Looks to be oil around the distributor.
My question is it a matter of pulling out the distributor and replacing the gasket or should I be looking for something else? Looks to be Item 16 gasket listed on the following site: http://www.perfprotech.com/store/assembly/DISTRIBUTOR-AND-IGNITION-COMPONENTS,1014-110.aspx
I believe the procedure for pulling the distributor is to mark location of the distributor to the intake manifold loosen bolt and pull the distributor out.
