wendellbee
- Joined
- Sep 3, 2014
- 40
i installed a new pertronix electronic dizzy along with a new coil and newer wires and plugs. i have noticed that the dizzy does not always turn when i was bumping the motor, using the starter, to get it to TDC.
i was able to get it to start one time (I shut it down since it's a marine engine and i did not have a water source hooked up). further attempts to start it were unsuccessful, so i rechecked timing and noticed that the dizzy, every once in a while would not turn when i was bumping the starter to get it back to TDC. the engine crank would rotate but not th dizzy. this caused the rotor to be out of position (not on #1 cylinder) when i got back to TDC. Is this caused by me bumping the starter or is there something else wrong. i tried this a few times and i'd say 80% of the time the rotor was positioned correctly but the other times the rotor was way off even though the pointer was at 0 . I tried turning by hand but it's difficult given the confined space (twin 460 inboards and the pulley has a raw water pump in the way). the previous dizzy was broken when i purchased the boat so i can't say if it had any issues.
