Distributor rotor button stuck
cj8mule
The motor is a 1978 120hp. I expected to change points and condensor but found this when I pulled the cap off:
It looks to me that a PO has done a conversion kit or something. Can anyone tell me what kit was used? The rotor button is stuck and will not pull off easily. Any suggestions on getting that button off???
Thanks,
--Dave
RogersJetboat454
Re: Distributor rotor button stuck
It's a Pertronix ignitor conversion. Should work fine for you as long as the weights and springs for the mechanical advance are not fouled up. From your picture, the rotor looks like it's in decent shape. If there are no screws holding it to the shaft, pull hard up on the rotor. If that doesn't work, pull harder... ;)
Ayuh,.... I know That 1 ain't Oem, but Mercruiser is known for Gluin' the rotor button on,....
Ya gotta Bust it up, to get it off....
Maybe the Op read 'bout that on the internet, 'n did the same thing.....
I'd have a Replacement, In hand, before I pulled Too darn hard..... ;)
stonyloam
If it runs, why not just leave it? I see no need to pull it off (no points to get to).
cj8mule
The motor is new to me. I have had it running while laying on the garage floor, but it was missing a little. Now that it is in the boat, it won't hardly run. Lots-of burping and backfiring through the carb. I put new plugs, wires, and cap on today (I usually change the button at the same time)
I also rebuilt the 2 barrel Rochester today but used the wrong measurements to set the float. The rebuild kit had different measurements than the merc service manual. I'll get that changed and she'll probably pure like a kitten.
Thanks for the help!
--dave
stonyloam
Do you have a full 12 volts going to the red wire on the electronic module? What do you have for a coil?
cj8mule
I've not checked yet Terry, but there is a resistor so I suspect around 9V. The coil is just a stocker.
dingdongs
the timing will still have to be checked at the stated rpm and you may have a compression and /or valve problem as in valve still open whilst firing or exhausting.if its the same as before putting new electrical sevice parts on i would be looking at a compression test after setting timing.
stonyloam
OK the Petronix needs the full 12 volts, and the coil needs the resistor in the circuit, so 9V for the coil should be about right. If the red wire is attached to the coil +, you should remove it and find a 12V source when the ignition is on that you can splice into. Perhaps the coil wire before the resistor. That will let your electronic module work at peak efficiency. No need to worry about dwell, just set the proper timing.
cj8mule
Thanks Terry. That's how the Petronix is wired.
stonyloam
Great, so you should be all set. One note, on that older model ignitor, you want to make sure that you don't leave the ignition on for an extended time without the engine running, it can burn out the module. If it ever fails, you would want to upgrade to the Ignitor II and Flamethrower II coil. Last thing, I wouldn't worry too much about replacing the rotor, especially if have a good blue spark from the plug wires.
cj8mule
Thanks for the info Terry! I finally have it running good now. The PO had the distributor at around 20 degree advanced instead of 8.
