Distributor Rotor Rotation?
Low Bridge
Is there ever an instance where a rotor in the distributor turns counter clockwise? Is it an indication some thing is obviously wrong? Can't get her to fire off-
1972 350 Chevy ChrisCraft/"Broadwater" -
Thank You
PS- I put her in the Tri Star-
MikDee
Banned
Re: Distributor Rotor Rotation?
It could be a reverse rotation motor?
Low Bridge
You know - this has driven crazy for 3 nites! I've primed the oil pump with the drill- clock wise- Hmmm I'm startin to think my starter is wrong?
RATS!
MikDee
Banned
It's not possible for a standard starter to crank in reverse, it would just spin without throwing the starter gear out to lockup with the flywheel. Maybe, it is a reverse rotation starter?
Low Bridge
Yes wrong starter, not wrong starter hook up-
That would explain the rotor going counter clockwise?
It's a gear reduction bottom mount- this bell housing has no top mount provision- ( I have 2 or 3 of those) laying around !
MikDee
Banned
Gear reduction? Don't they normally spin the wrong way with the extra gear?
Low Bridge
Right now I'm one fickled Flounder. It's looking that way- I need to pull it guess !
Ayuh,...
With a Chevy,... Righthanded, or Lefthanded, the Distributer Always turns the Same way....
Only the Crankshaft turns Backwards....
