Distributor
clasavi
have a 1998 mercuries 350 EFI MPI
Engine Serial OL067176
Sterndrive OL153367
When installing the distributor shaft do I want the engine on tdc or at 10 degree?
Re: Distributor
Sterndrive OL153367
Ayuh,.... Motor at Tdc, rotor pointin' at the #1 tower of the cap,....
MikDee
Banned
Re: Distributor
Be sure you're on #1 at TDC, (compression, valves closed). The Crank set at TDC could also be #6 the opposing cylinder on small block Chevy's (no compression, valves open). Or, vice versa, check for this, that's the way it is on a 4-Cycle engine
clasavi
Re: Distributor
Well, I can't see to get it right. When I put wot it backfires and bugs down. What am I doing wrong?
Is the grove on the harmonic balancer tdc when lined up with the mark on the block?
clasavi
Re: Distributor
Yes but maybe I don't know what im going. Are there any instructions on here. I would say that the fact it cranks It's an improvement.
What do I do after that
clasavi
Re: Distributor
The stores are closed and I don't have a timing tool. Can someone tell me which two color wires need to be looped in order to put it in timing mode?
Re: Distributor
350 EFI MPI
Ayuh,.... I maybe wrong, but I believe with yer motor, ya stab the distributor as I said above,....
'n the computer times the motor after that,....
Without a timin' light, you won't have a clue anyways,...
Do ya have the Manual for yer motor,..??
It might be available up in Don'S Adults Only section, at the top of the forum,...
wrench 3
Re: Distributor
If you have a sensor on the lower corner of the starboard side of the timing cover, the computer uses that to adjust the ignition timing. Hence, when you turn the distributor you're not changing when the coil produces a spark. However, you are controlling which cylinder the spark goes too. Normally you would use a scan tool to adjust the synchronization. Instead of that you may be able to get it to run right by trial and error. If it starts running bad when the RPM rises, most likely when the computer advances the timing the spark is going to one cylinder ahead of the one it was going to. So you need to rotate the distributor counterclockwise until the spark returns to the proper cylinder.
Move it a little bit at a time and test it out on the water between each adjustment.
thumpar
Re: Distributor
Make sure you have the firing order correct also.
Bt Doctur
Re: Distributor
