mariner man 66
- Joined
- Aug 9, 2005
- 20
can anyone tell me the purpose of the divider plate that sits inside the exhaust cover or the rear of my 135 V6 1991 mod and what could happen if the divider plate seal isn't doing it's job.<br />The reason why I ask this is that I was doing a compression check today on my v6 135. I found that it was a bit low at 100 in each pot. I decided to spray same oil into the cylinders to see if this would help increase compression. As I had all the plugs out I noticed as I was spaying the oil in (with spray gun hooked up to air compressor I noticed that this oil vapour was coming out of one of the spark plug holes on the opposite bank of cylinders. Does this mean that the divider seal behind the exhaust cover is no good? Or am I just worried for nothing.<br />I am trying to fault find the cause of the motor bogging down under acc. from idle. Thanks
