DIY in floor storage
Hcozart
Tips or previous experience on installing/building in floor storage compartment on pontoon?
MH Hawker
you can make any shape out of fiber glass, thats how the the rice rocket boys make a lot of the shapes for their car, its a simple thing actually, with a wire frame and a felt blanket and resin or even thin wood or insulation board
ahicks
"In Floor" that hangs down below the floor stringers might be a bad plan if your boat ever sees a pontoon boat lift or scissor type pontoon trailer?
depending on your structure, you can do shallow in-floor between the structures. was even offered on many 'toons as standard as a location for the anchor ropes
HotTommy
Hcozart,
If you are considering anything more than a shallow space for small stuff, you ought to look at this video first. There's a lot of water impact on the underside of the deck of many pontoon boats.
