Hi <br />I have viewed a couple of posts here about The V4's <br />Block ground cable being prone to unseen corrosion<br />causing starting issues. I think I may have a few of these issues since I have had a few dud turns of the key with the starter just spinning real slow, or just a click. Then I tightened the wing nust on the battery and it started fine. Then it did it again.<br />My question is where is this ground point located on the block so I can pull it off and clean it up.<br />I looked and I'm not sure where it is.<br />thanks <br />H90 1985 EV 90
