djohns19 ,slowly sinking
derwood
hey bud , that motor that i have been having the trouble with is attached to the leakest john boat this side of the rio grand. i saw your reply on the other guys post. What is that stuff gluv it or something. yesterday when i took the boat out i would have been dryer if i was outside the boat swiming behind it. More like pushing it the way the motor ran twords the end ,if i did not sink from the weight of the cresant wrenchs in my pocket.(sorry guys inside joke) some of the rivets are loose and there are two holes in the bottom near the back. an old timer at lowes told me the way he used to fix airplane skin that got holes in it from rocks on the runway. he said that i should get that 5 min. epoxy and some alunimum. clean the spot up till shiney but not smooth and epoxy the alunimum to the hole . he also said to just epoxy the rivets and they would hold. well on the way back in the water level in the back of the boat was the same as the water outside the boat. if i wanted a sore but and wet feet i'd go tubeing down the verde river again out there in your neck of the woods. i did not know you could tighten rivets. dose it take a special tool or something. got to go, see ya.
cannonfodder
Re: djohns19 ,slowly sinking
I think you should be able to tighten the rivets with a dolly block with an indentation in it just slightly smaller than the head of the rivet. Get a big punch and hammer. The punch will need a similar indent.The heavier the dolly the better. Get a friend to hold the dolly on the inside against the rivet you want to tighten and hit it with the punch and hammer on the outside. Be careful not to get carried away as aluminum is relatively soft. This is what I think. See if there are similar opinions. Bryce
D
DJ
Guest
derwood,<br /><br />Bryce gives good advice for tightening up really loose rivets. Gluv It is basically an epoxy. It's better to work with though. It has a good two hour pot life and doesn't smell to high heaven. It's about $35.00/quart. A quart will do your whole boat. You can get it at: www.westmarine.com. <br /><br />Don't be alarmed when you open the can and it's only 2/3 full. that's the way it is supposed to be. It allows you to mix the product in the can.
derwood
dolly huh ... Thats way to tempting. I guess if you know what a dolly is you have heard all the razzamatazz. i sort of know what it is but i don't have one anyway. there is a marine shop down the road from me , do you think they would charge alot to tighten up a few rivets? :eek:
derwood
your right ...I do want to fix it myself. Badly. I hate to pay someone to fix something that i can fix myself myself. the reason that i have'nt done it is because i don't have a dolly.( that's a free shot on my manhood. should have worded that better.)djohns is a smart feller. he and allen have helped me a lot just to name a few. dose anyone know of a shade tree substitute for a dolly? ( man i've got to word this stuff more carfuly. someone could get the wroung idea.) I will look for a used one. i have a little time to do this while i fix the motor. maby i'll buy a new one if they are'nt to exspesive. thing is ... how do you go to the man store and ask for thier best dolly with out it comming out wroung. <br /> Thanks Derwood. :D
cannonfodder
On the dolly thing. Use a piece of steel rod at least 1 inch in diameter and 2 ft long.In the end, on a center punch mark drill a shallow hole slightly less than the height and width of the rivet head. Hope this helps. If not ask some more questions. Bryce
