Do AN fittings require a sealer?
CN Spots
There was no mention of it on the manufacturer's site. These are for fuel lines btw. Thanks.
spots
roscoe
Re: Do AN fittings require a sealer?
Sorry, but I've got a mind block. What are AN fittings?
Kenneth Brown
AN fittings are commanly used on race cars/hot rods. The A/N stands for Aircraft/Navy. They do not need a sealer. If not mistaken they use a 37 degree JIC taper seal. Make sure theres no burrs on the threads or the mating surfaces and all is good.
Scaaty
Nope... clean, easy, snug...
CN Spots
Sweet. Thanks!
Kenneth Brown
For additional info- The size divided by 2 is how many 1/8's of an inch it is. Lets say you have a #8 line and fitting, its a 1/2" size while a #6 is a 3/8".
speedwrench
They don't need sealer, but never-seize is a good idea since they have a tendency to gall.
Dave
angus63
Don't use anything you don't want in your fuel system eventually. I use AN fittings for aircraft heat exchanger designs and all we use is a light primer mask to separate dissimilar metals. No sealer required if threads are clean and to spec.
burroak
:D Why not indicate that the AN # is 1/16th of an inch? Dibisun are hard.:D
