Do boats use an o2 sensor?
slimfitz
Just curious here. I got to thinking about my motor. Im not sure if I have a o2 sensor. I have a 97 Volvo 7.4 LK model. How does the motor adjust the fuel and timing if it doesnt measure the unburned gases? I know it uses a map sensor but I cant seem to find an o2 sensor on the exhaust side. I assume it runs in open loop? Just using a pre determined fuel map?
Sherminator
Re: Do boats use an o2 sensor?
If it is a Fuel injected engine, more than likely it will have some sort of O2 sensor. If it is a carb you probably will not have one.
agallant80
if it is newer and has cats there will be one before and one after each cat. I have 4 on my boat.
slimfitz
Well I have searched my exhaust and do not see them. Where would they be located? I would imagine that it is going to be on the riser? I even went through my parts diagram. They dont show one either.
slimfitz
Just to clear things up. My boat is probably the first year of fuel injection. It is a 1997 Volvo Penta 7.4 LK. I have no cats. I didnt even know that cats were on boats now. I guess emissions is now an issue with boats. I know that if it has a cat it has to have an o2 sensor just so it can correct the mixture. Did the early boats just run on a pre determined fuel map?
slimfitz
Thank you Don S, that makes alot more sense now.
E4ODnut
Slim,
Don's reply is correct. You are also correct in that it runs open loop (with respect to Exhaust Gas Oxygen feed back) on a predetermined program. No doubt an O2 sensor was used to determine that program. As far as I know the latest flavors of marine EFI now use an O2 sensor and closed loop to keep a tighter control on emissions.
