I was just told by a dealer that the deep cycle batteries have a memory. He said that the batteries have a certain number of recharging cycles built into them. So if you recharge when the battery is only 50% depleted, you use up one of those cycles the same as you would if it was 100% depleted. Is this true? He said it would be best to fully discharge the battery each time you use it before you recharge. Can I take this to mean that topping a battery off once a month while it is in storage in the winter would use up one of those cycles and "waste" it?<br /><br />He also said the gel cell batteries give you more power than the lead acid types. Any opinions on this? Are the gel cells worth the extra cost?<br /><br />Thanks.
