I have a 1984 Searay with an MCM 140 HP 3.0L engine...It came with a 2 barrel carb on it and it had the accelerator pump that was "straight" no t bend at the top...I got another carb I put on the boat that has the "bent" accelerator pump in it...I am having the same issues of not getting enough fuel...just checked the fuel pump...its good, the filter was pretty clogged...not sure if this would cause my problem though...(filled it with water and it takes about 10-15 seconds to drain out through the sides of the filter? Here are the two numbers off the metal tags on the carbs...I need to know which I have to see what rebuild kit to get...thanks...does it matter which one I use? The original was MCM 120/140 1389-8490....straight pump....the one on there now, bent pump is MCM 120/140 1389-9562. Thanks again for all your help.
