Do I have a tell-tale?
DaMoos
1978 evinrude 85. Does this motor have a tell tale? Can't find it peeing anywhere. There are two little holes on the back of the motor that seem to spit out exaust. I assume this is normal. Other than the too low idle when warm mentioned in a previous post, the motor seems to run fine.
ezeke
Re: Do I have a tell-tale?
The 1978 motor should have a tell-tale. The outlet should be at the bottom of the exhaust cover which is the center panel between the two cylinder banks. A hose should lead from there to the floor of the lower cover.
The fitting at the exhaust cover is 1/8 NPT which is quite small and easily clogged.
If you don't find the tell-tale mounted, there is a lengthy discussion in the Engine FAQ forum on this site.
Click the thumbnail, please.
