Do I have a thermostat
circle hook
I have a 1984 7 1/2 HP and the book shows a picture of an 9.8HP and says other models are the same, but I can not find the thermostat and it dosen't even look the same anyone know if this engine has one and if where is it located. Thanks Bob
emckelvy
Re: Do I have a thermostat
Some do, others don't, depending on year. If you do have a thermostat, it's built into the exhaust manifold cover on the Port side of the powerhead.
There's a casting for the 'stat at the top of the manifold. The thermostat cover is held on by a snap-over spring-thingy. Thermostat directly under that cover.
If you don't have that, you don't have a thermostat.
Here's a parts diagram showing a manifold cover equipped with thermostat:
http://www.mercruiserparts.com/Show...97&bnbr=80&bdesc=CYLINDER+BLOCK+AND+CRANKCASE
HTH...........ed
