My apologizes if this is the wrong place to ask this question. I have a 1995 Grady White Islander (26.8). It has a 2004 Merc 225 with a 30" shaft. I'm confused whether this is the right length or to long. The boat struggle to get on plane. The transom is 21". However the keel is 28" forward of the transom (swim platform where OB is mounted). Running a straight edge from keel to the cavitation plate the plate is about 1' higher. So do I lower the engine 1" (which I can do as it is mounted in the bottom holes) or raise it 10" (remove the OB shaft extension)? Thanks Tom
