hey guys, been a while since I have been on here, busy with life and all.. So ill cut right to the chase, i have an 1989 Bayliner Sunbridge 2455, 24 FT. replaced the motor over the winter, and took it out for a test run this past weekend, run great. hooked up the threw hull exhaust ports, turns heads when it starts, the motor is a GM 350, bored .030, comp cam, high rise intake, 600 cfm carb, and the out drive is alpha one. the prop on there is a stainless 3 blade, 15p, which is the pitch im guessing, i dont recall the exact numbers, but its 19***** 15p. so what my concern is, is how long the boat takes to plane out. almost embarrassing to have a nice sounding boat, and it cant get up , im usually and where from 2/3 to 3/4 throttle, and it takes a but to finally get up, and once its donse, its at 4500-4600 rpm, and runs about 30mph, so is there a different size prop i could try to get up faster, maybe have a faster top speed? i can rebuild motors all day, but im unfamiliar with the prop sizes, and what to look for, and what to compare with as far as prop size to engine size ratio. thanks for the help! im hoping i can look around and find some used ones maybe and see how they work over the next couple weeks, thanks again!
