Re: Do I have this correct?
So that it looks like it was done when the boat was first made, do it in a similar way they did.<br /><br />Make the part like you just discribed, but make it thin, then glass over the whole thing when it's in place. This way the finish will look the same as the rest of the boat. For the part (box) use 1 mat, 1 roving and then 1 mat. use that same layup over it when it's in place. It should be strong enough, if not put on another layer of glass.<br />Don't use cloth for any of it.<br /><br />You don't need to use PVA on the wood, just use wax, put it on very heavy and don't wipe it off.<br /><br />Use "Green Wax" if you can find it, but most release waxes will work. The inside of the box won't have great finish if this method is used, but it is very inexpensive.
