Do I have to pull the flywheel?????
cvlngineer
Will I have to remove the flywheel to get to the wristpins, or can I just open the crankshaft case with it still on?<br /><br />Thanks,<br />cvlngineer
steelespike
Re: Do I have to pull the flywheel?????
My guess is yes you have to remove the flywheel.<br /> What model motor are you talking about?
Walker
You have to pull it and also remove the stator coil and the rest of the ignition that is under the flywheel. Then you have to take out the bolts in the top main bearing carrier. You'll see it when you get the ignition and stator out of the way. There is a bearing carrier on the bottom too.
cvlngineer
Walker,<br /><br />Thank you very much! <br /><br />cvlngineer
