Ok, i appreciate any help i can get on this one. I just purchased a 2000 Starcraft 2010 with a 350mag/300hp with a Bravo 1 outdrive. I just had a merc remanufactured long block put in, so i have been easy on it so far this spring trying to break it in. I have about 10 hours on it now, so i decided to try WOT for a bit, because i know i have the wrong prop on it now. First of all i started off with a 15X22 pitch prop four blade Mercury Marine Bravo 1 SS prop, with a little ding in one of the blades, does that make a big difference. I could not get the thing out of the water no matter how hard i tried with no weight in the bow. The guy i purchased the boat from had a 21 pitch prop that i tried over the weekend. I measured it, and it came to be a 14.25 X 21 pitch. The prop is a Mercury Marine Tempest three blade SS, but has been reworked, and i suppose is a spare prop now. I don't think there is any cup in it, or rake. But on this one i still can't get the boat out of the water, if there is no weight in the bow. The 21 pitch prop is the one that i tested the WOT on. so here it goes, and i haven't seen anything on any other threads about this. I can only get 4000 rpm out of the motor, and i know that i can damage the motor with that low of rpm. I should be between 4600 and 5000.
So, the performance that i want is to get the boat out of the water and get it to plane faster, pull up skiers and tubing.
Current prop is the Merc Marine Tempest 21 pitch three blade SS.
14.25 X 21 pitch, reworked.
WOT should be between 4600 and 5000, but i am only at 4000. Speed in on spedo at 58. This was not at normal load. Empty tank of gas and just me, 200lbs.
It has the 350mag with MPI fuel injection year is a 2000. Rated at 300 HP and has the Bravo 1 with the 1.50 gears.
The boat is a 2000 Starcraft 2010 fiberglass 20ft boat. On my title is states the boat is 3200lbs, so i'm assuming thats with the motor. Has a 45 gal. fuel tank.
Any help with this would be great.
