JoeW
- Joined
- Nov 8, 2003
- 664
I'm trying to restore a 1998 17' Starcraft aluminum hull. It was a theft recovery that I got from a local marin recking yard. Anyway, I have a 1988 Mercury O/B 100 hp (from a 1988 SeaRay runnabout) that I've mounted on the hull. I'm trying to connect the control box that was left on the boat to my engine. The throttle cable seems to be ok. But when I try to attach the shifter cable I have to set the shift lever on the engine to reverse (all the way aft) in order to get the cable on, even when the control box lever is in neutral position. When I try to shift into forward gear from the control box, I get only to neutral. <br />Am I finding out the hard way that these control boxes are closely matched to the engine type? Do I have to find a control box like the original one that came with this engine? Are there any conversion kits or is there something I can do to reposition the cable in the box? I really wanted to try and use the control that was on the boat. It looked much better than the one I had on the SeaRay.<br />Any help is appreciated!<br />
