What do you think I should replace to get some current to the battery?
I've done these measurements with a cheap multimeter.
The voltage over the battery is 11.96 V without as well as with the engine running (at idle or higher rpm).
The AC over the stator's yellow and yellow/grey cables is around 6-9 V at idle and 17-20 V at higher rpm, with very fluctuating values.
The DC over the rectifier's red cable and ground is 12.1-12.5 V at both idle and higher rpm, maybe a tenth higher at the higher rpm.
It doesn't seem to be any short circuit between the rectifier's red cable and ground.
I've tested the rectifier and it passes current in one direction to the red, yellow and yellow/grey cables (all in the same direction) but not the other, the resistance is higher in the red cable than the yellow and yellow/grey.
The resistance between the stator's yellow and yellow/grey cable is a little more than 1 ohm.
The resistance between the stator's yellow or yellow/grey cable to ground is less than 1 ohm - is current really supposed to pass from the stator to ground?
So, what do you think, what should I replace to get current to the battery?
Could the low voltage in the battery be causing this, should I run the boat at high speed for half an hour and see if the voltage increases?
