Hello & Help Help !!
Do I need a puller to R & R 35 HP (1971 or 72) Chrysler Propeller shaft seal?
1. I have pulled the propeller and two hex bolts, a puller appears needed. Is
a puller or some force needed? Please Advise! Puller is my guess.
2. Are the two holes perpendicular to the hex bolts for a puller or used with
bolts and washers to pull the housing behind the propeller?
3. This is a larger leak to loose the oil showing in the attachment in 8 hours
Thanks,
JOW
. Thanks,
JOW
