bosshossmc
- Joined
- Jun 10, 2009
- 33
I have a 1993 VIP Vision 1760 with a 3.0L and a alpha 1 Gen 2 drive. I am in the process af replacing the stringers and floor and had to remove the motor to do so. I had heard that you need to align the motor to the drive. Does this only apply when removing the drive from the boat? From what I can see is that in order to align the motor with the gimbal I would need to remove the outdrive. Correct? As I see it I am just bolting the motor back to the bellhousing which hasn't moved and the drive hasent either. Everything should be good. Am I getting this right? Thanks
