Re: Do I need to avoid Bayliners?
A hull is a hull, really. What you should consider most is the amount of wood and if it is rotten and the engine/outdrive. If the wood is rotten, you can get a good deal if you have the time/inclination to replace it yourself. For the motor, just make sure it is still made/supported (OMC isn't, Force is iffy at best, Mercury engine [470?] is no longer made and parts are rare). Beyond that, there really isn't much to a boat. Buy the one you like the looks of, matches you budget, can do what you want and will be reliable to you (reliable is subjective.. some people like a beater, some like a warranty). The boat which matches you in each of these categories is precisely the boat you should buy, be it a Bayliner, Chris Craft, Sea Ray or a dinghy.
