Re: Do I really need to use a surface gap plug?
First, never run NGK plugs in that motor. With todays fuel the Champion QL77JC4 plug is just fine.
Please explain?
Fucawi................Almost every motor built within the last 30 years is powered by a capacitive discharge ignition. Plenty run standard electrode plugs, why would OMC call for regular electrode plugs in their other motors if this were the case?
You can run the ql77jc4's or the ql77cc's or b9hs10 down to the 7's if you have problems with fowling. Some of the head castings will allow even you to run the projected tip ql78yc's.
I have found that the NGK BU8H seems to work the best and are as cheap as the champions, cost wise.
Old rude got it right........surface gap for wfo running, regular electrode will run a little better if you do a lot of idling.
