Hi again,<br /><br /> I am finally starting on my project boat. It has a 1970 85hp Johnson. From reading some of the posts here you should change the impeller in the water pump frequently because they can take a "set" even if the motor is just in storage and has low hours. My question is, do impellers have a shelf life? If the dealer has "new" impellers in stock that are as old as the motor is there a risk of them being bad? If so, how can you insure you are getting a "fresh" one?
<br />Best regards,<br />RCS
