Do the drain plugs go on the inside or outside?
Patty Pooh
I just boudht a boat and i dont know if they go on inside or outside of the boat
rickdb1boat
Re: Do the drain plugs go on the inside or outside?
Bilge drain plug goes on the inside of the boat.
JB
Ditto Rick.
Dhadley
The inside if you can get to it easily. If not the outside will work fine. If your plug is the lever type and its in from the outside just make sure the lever in not pointed down under the hull.<br /><br />The important thing is to know where your spare one is, regardless of where the main one is.<br /><br />Good luck!
