Do these cylinders need rebore Pics
TrickyRicky
1978 55hp 001.jpg1978 55hp 002.jpg1978 55hp 004.jpg[[/ATTACH]1978 55hp 002.jpgThink these cylinders need rebore? I think it was run with carb cleaner and the skirts started to gald. Top of bore looks good. Recently bought powerhead did not rn it myself. 2 cyl 55hp 1978. Had 150 compression.
HighTrim
Re: Do these cylinders need rebore Pics
Have you mic'd it?
boobie
From the pics it looks like rebore time.
Lone Duck
View attachment 179198View attachment 179199View attachment 179195[[/ATTACH]View attachment 179199Think these cylinders need rebore? I think it was run with carb cleaner and the skirts started to gald. Top of bore looks good. Recently bought powerhead did not rn it myself. 2 cyl 55hp 1978. Had 150 compression.
As a general rule, If you can feel the scratch with your finger nail, it is time to recross thatch or rebore depending on depth fingernail goes in scratch.
emdsapmgr
If you were to hone it and put in new rings, it will probably run. Over time, the carbon from cylinder combustion will start to seep down those grooves and promote carbon around the ringsets and piston skirts, shortening engine life. Time for a rebore.
retiredfornow
Yup, if you're down that far, rebore it and worry no more.
