jgresham75
- Joined
- Aug 19, 2008
- 70
I have 99 5.7GL with new long block and new Holley 2300. Trying to set up carb. I have gotten idle mixture, idle speed and timing down and it idles great. Now I am focused on turning after idle. I got a bog off idle. I can go slowly up to speed so I am working on setting power valve and accelerator pump action but focused most on power valve.
Do these vacuum readings sound reasonable?
1. At idle, I have 17.5" at 650 rpm using manifold vacuum at about 8 degrees on timing. Idles great. From other information I have obtained, that sounds good for a car motor but should a marine engine exhibit the same vacuum at idle?
2. Under load, vacuum fluctuates between 9-12. Does this sound appropriate for marine engine? In trying to set power valve using either half of idle vacuum or 2 down from load vacuum, that would put a power valve at around 8.5. Manual says 4.5. Does having such a larger power valve from manual sound right, even though it is based upon actual vacuum readings? I am running a 7.5 power valve with a slight bog so based on this, the 8.5 may resolve bog.
3. Under load, as mentioned above, the vacuum gauge fluctuated by about 3" from 9-12. Does this range of fluctuation sound normal under load? At idle, vacuum stay very constant within about .5".
Thanks for your help. Not real savvy on carb tuning but I am learning.
