do this will stop carb gum up?
jjdluz
i know lots of carb after sit for while it will gum up,will drain the bowl of carb will stop gum up?all it take is loss the drain let the remain gas out,correct?thanks.
Ray Neudecker
Re: do this will stop carb gum up?
Emptying the fuel from the carbs before storing is the best mathod of keeping the carbs from gumming up.
Silvertip
Draining carbs is another rather controversial topic. The residue left in the carb after draining is what gums them up. Treating the fuel with a stabilier, then running the engine until the mixture has reached the carbs will ensure the carb stays full and protected during storage. No air -- no contamination.
rodbolt
if it aint there it cant gum.
however if you dont drain the rest of the fuel system the gummy crud enters the carb at the next start up.
either treat thye fuel or drain the ENTIRE fuel system.
