Re: DOA wiring, big boat....
The very first step in this process is to determine what type of "Boat" and "Engine" wiring scheme is used. Yes -- there are two electrical systems in a boat. The "boat" system feeds electrical power from the battery(ies) to the console/cabin where it is distributed to the various 12 volt circuits in the boat. The "engne" harness has the circuits related to the engine and usually run to the helm. All of the sender signals (oil pressure, water temp, tach, etc) are in that harness as well as the ignition and starting circuits. Gauges are typically wired in the fashion shown in the sticky titled "Generic Boat Wiring Diagram" at the very top of this forum. In your case, the gauges would be x2 with the feeds for the tach, water temp, oil pressure, and any other engine-specific gauge duplicated. Gauges are typically fed power from the ignition switch so engine-specific gauges would be wired to the ignition switch for that specific engine. There is likely a fuel level selector switch and a single gauge for fuel level or there may be three separate gauges without the switch. Fuel and speedometer for example are not engine-specific gauges so don't look in the engine control harnesses for that wiring.
