Re: DODGE Ram 1500 V-8 Magnum
thanks 12 footer this one seems to match what i am going thru.but the light does not stay on all the time it surges and bad gas milleage when the light is on then goes to normal when light is off
<br /><br />*51 Oxygen sensor stuck at lean position (Bob Lincoln wrote: may be tripped by a bad MAP sensor system causing a rich condition, and the O2 sensor trying to compensate. The O2 sensor may still be good. The MAP assembly consists of two pieces, the valve and the vacuum transducer (round plastic unit with cylinder on top and both electrical and vacuum connections) - If you get hot rough idle and stalling, especially on deceleration, accompanied by flooded engine and difficulty restarting, that can be a bad MAP sensor causing the O2 sensor to try to compensate. If you get poor cold driveability, stumbling and bucking, and acceptable warm driving with poor gas mileage (a drop of 10 mpg or more), that is usually the O2 sensor. [Webmaster note: MAP sensors seem to die regularly.]
