Does a 1972 evinrude 100hp O/B have a pee hole
heyitswebb
I have a 1972 100hp starflite ser#0-27678 model #100293R . how do i know if teh water punp is working, does it have a pee hole? or is there a way to make one if there is not one? also looking for a web-site where I can veiw engine drawings till my seloc manual comes in. <br />Thanks Tim
heyitswebb
Re: Does a 1972 evinrude 100hp O/B have a pee hole
need help before burning up motor
alcan
No your motor does not have a tell-tale (pee-hole). It uses a heat sending unit that sends a signal to a light on the dash panal. How ever you should see water comming out the exhaust by-pass ports on the back of the leg. Your cooling system is also controled by t-stats. How do you tell if your motor is to hot with out a thermometer? Take a hand full of water and drizzle over the head/cylender area (both banks in your case). If the water sizzles and dries up fast it's too hot. If the water just sort of rolls around and steams a little it's ok. You obviously just got this motor. The very best way to know if your cooling system is working is to replace the pump empeller and inspect and service the rest.
