Does anyone know the thickness of the hull on a 2004 Glastron 205?
toddbrown
DHPMARINE
Re: Does anyone know the thickness of the hull on a 2004 Glastron 205?
Probably changes with where you measure.Transom thick,elsewhere variable.<br /><br />What are you trying to do ?<br /><br />DHP
toddbrown
I ordered a wakeboard tower and need to see if I will need to build up the fiberglass.
toddbrown
it needs to be 3/8 inch think
Reel Poor
That tower is probably going to mount to the upper hull deck. With sufficient backing plates (aluminum or stainless) you should be fine. In most cases the thickness in an area the tower will mount is probably 1/4 to 3/8 inch thick.
toddbrown
Ok, that is what I was thinking but you never know.
WillyBWright
That's a Vec hull? You may find it difficult to be able to get to the backside of the fasteners. You may have to cut access holes and cover them with cover plates
toddbrown
Yeah it is VEC. Dang it! I have to cut access holes. That is going to look really bad.
