does anyone know the timing specs on a 66 60hp johnson
billbass9
i was wondering if anyone knows the timing specs for a 1966 johnson 60hp the model# on itis v4sl-12s ser# 2l01808 by timing spec i mean were to time it how many degrees before or after top dead center or right on once again if you can please help me thank you for your time i was a;so wondering if anyone knows the stock carb hi low speed ilde needle adjustment thanks for your help and time
jimmbo
Re: does anyone know the timing specs on a 66 60hp johnson
V4SL-12 shows up as a 1960 75hp. Does this engine have magneteo or battery ignition? <br /><br />Timing on these engines is set by the point gap 0.020". On the battery system The cam on the distributor shaft should have reference mark showing where the point rubbing block should be when the point gap is at its widest.<br />The magneteo system is set similarly. There are some timing reference marks on the flywheel/block and on the distributor pulley/bracket. These marks are used for installing the timing belt. Carb seting were 1 1/2 from lightly seated. Once adjusted seperately for best idle the syncronization link between the two can be hooked up.<br />OH the Heck with it GET A SERVICE MANUAL, it will explain it and show pictures.
billbass9
i thouht it was but another guy told me it was a 60 itis a battery ignition do you know how many degrees the number 1 piston should be before or after top dead center thanks for the info
jimmbo
They did not set the timing on these engines like that. It is set by setting the points to open at a particular spot. Get a manual cause it isn't easy to explain it without the neccessary pictures and diagrams. Regarding the model/year, if it is a 1960 75hp it would have a magneteo ignition. the 61 thru 67 could have either magneteo or battery ignition.
billbass9
ok thanks ill get a manual
billbass9
would you happen to know were i could find a alternator and belt for that same engine online or anywere thanks again
jimmbo
e-bay? If it used a belt it was a generator, alternators were under the flywheel
billbass9
once again thanks
russeller
i would try a napa that is where i get alot of my parts
billbass9
thanks for the help everyone i realy needed it
